Go Back   Automotive Forums Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 05-16-2003, 04:53 PM
jag98 jag98 is offline
Smile Remote keyless entry programming
Can anyone tell me how to program the remote or point me to a a site that can?
Thanx -
Old 02-13-2004, 11:39 AM
jalopys jalopys is offline
Re: Remote keyless entry programming
Did you get the programming insturctions for the keyless remote on the XJ8? I am trying to fine them.
Old 03-03-2005, 10:36 AM
vasau vasau is offline
As far as I know the jaguar remotes can be programmed only with transmitter equipment.
Old 11-22-2005, 12:05 PM
mwriccitx mwriccitx is offline
I have a 98 XJ8 Vanden Plas and I can not get into Programming mode using the proper instructions. I also can not get the garage door opener button to opertae even thought the light blinks like it is working.
Are these problems related ???
Old 11-22-2005, 12:50 PM
Jaguar D-Type Jaguar D-Type is offline
Banned
Check your local Jaguar dealer or an independent Jaguar repair shop.
Old 11-25-2005, 06:47 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Direct Link - http://originalkeyless.com/searchqui...ords=K8597T315
FCC # - K8597T315
CANADA - 2145101790
Part # - LJA2610AA
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 04-18-2006, 02:13 PM
AutoKeys AutoKeys is offline
Ok, I always check these great forums for help and I noticed many had problems with XJ8 remote programming. So I decided to join and after feeding off of many usefull tips in the past, thought it's time to pass on some info which came usefull to me, and worked.
The following procedure is tested & worked on a 1999 Jaguar XJ8 and successfully added a Jaguar remote 315 MHz - FCC: K8597T315 - LJA261OAA.
Note : All transmitters being serviced must be available. If the learning process is carried out without having all the transmitters present, all previous transmitter codes will be overwritten, rendering the missing transmitters inoperable.
Hold headlight flasher back.
Turn ignition key to position 1.
Flash headlights 4 times.
Alarm will enter programming mode.
This will be confirmed by "beeps" from the alarm and flashing led on gearshift.
Program each transmitter (up to 5) by pressing the lock or unlock button on each transmitter once.
The alarm will "honk" when you press the transmitter button.
The alarm must honk 5 times to complete the programming. Therefore, if you are only programming one transmitter you should operate the transmitter 5 times.
If you are programming two transmitters you will operate one transmitter twice, and three times on the other.
For five transmitters you will operate each transmitter once.
Good Luck!
Tony
Auto Key Store
Old 11-08-2006, 03:18 PM
pafleur pafleur is offline
I can't get these instructions to work on my 99 XJ8. Maybe I'm doing something wrong. By position 1, do you me the position in which the radio works? Also, "flash the headlights 4 times"..are you meaning turn the rotating arm 4 times?
My husband just purchased this car a week ago and I'm trying to surprise him by purchasing and programming the remotes. So far, I've had no luck with the programming part.
Any help is greatly appreciated.
Old 02-06-2007, 09:13 AM
Northeast Marine Northeast Marine is offline
I need to know how to program a 95 Chevy suburban
Old 04-01-2007, 05:39 PM
autouch autouch is offline
hi,
ANY LUCK GETTING YOUR REMOTES PROGRAMMED??
IF SO I WOULD LOVE TO FIND OUT HOW YOU DID IT
THANKS
AUTOUCH
Old 05-06-2007, 10:13 PM
fparrino fparrino is offline
There are some instructions at this web site:
programyourkeys.com
There are some instructions for the XJ8, although they didn't say which years. It's worth a try.
Frank
