Old 08-31-2010, 09:59 PM
denle denle is offline
Enamel paint
Is Testor enamel paint fully compatible with Tamiya enamel paint? (I mean their thinners and paints)
Old 09-02-2010, 06:19 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Enamel paint
At least, I haven't had any problem thinning Tamiya enamel paints with Testor (and also Model Master) enamel thinner. But I've never tried the other way around (Tamiya thinner for Testor enamel paints), or mixing Testor and Tamiya enamel paints.
Hiroaki Fukuda
Old 09-02-2010, 07:38 AM
Re: Enamel paint
That's good enough, it's harder to get Testor enamel thinner in North America than Tamiya
Thanks
Old 09-03-2010, 01:31 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: Enamel paint
It is? Ive never had any problems getting the Testors thinner, and up until a few weeks ago, I didnt even know that Tamiya made enamels.
Old 09-04-2010, 11:10 AM
Re: Enamel paint
ooops, typo mistake, it's the other way -> harder to get tamiya enamel thinner in NA.
They still make enamel paint, but just not sold in NA. I guess shipping tamiya enamel paint to NA is more easy than tamiya enamel thinner.
Old 09-06-2010, 12:51 AM
Re: Enamel paint
Ah, gotcha. Yea, it was a big surprise for me when I found the Tamiya enamels listed on their site. A friend of mine owns the local hobby shop, and even he didnt know they made enamels.
Old 09-07-2010, 03:33 AM
mrawl's Avatar
mrawl mrawl is offline
Re: Enamel paint
Warning: Testors enamel thinner is good stuff, but it contains lacquer thinner. Don't try to use it to wipe enamel paint off a lacquer base, eg, when cleaning up trim lines. Other enamel thinners do not contain lacquer thinner and can be used safely with enamel over lacquer, eg, mineral spirits.
Mark R
Old 09-07-2010, 07:18 AM
Vladamor's Avatar
Vladamor Vladamor is offline
Send a message via MSN to Vladamor
Re: Enamel paint
Ok, I prefer Tamiya enamels over the other brands. But I'm going to tell you a little trick I'm using. I'm not using Brands thinners, because they're very very expensive for what they are. I'm using (called in Spain Aguarras or Trementina) Turpentine. Only for enamel paints. And know what?? It works perfect, cost me around 1.30 € per litre, and the result is exactly the same of their prducts. Never had any problems using it. And it's a good investment if you're using your enamel paints for airbrushing, like me...
I hope this helps some of you.
REGARDS
P.S. Make some test first. I put my hands in fire to tell it works, but maybe something can be different
Old 09-07-2010, 07:53 AM
Re: Enamel paint
Vladmar : I only use enamel paint for trim lines and weathering, not airbrushing. But thanks for your info.
mrawl : I guess I will avoid Testor thinner in that case and use lighter fluid for clean the trim lines when my last drops of tamiya enamel thinner is used up.
