Old 08-31-2010, 10:34 PM
94cordvtec 94cordvtec is offline
91 si have spark and fuel just no start????
i have a 91 si hatch and recently my fuel pump took a deuce, it wouldnt come one or anything so i tried swappin my main relay with a known good one and it still did nothing so i changed he fuel pump out with a new one and i have fuel, with the bleeder screw out of filter, gas will shoot up to the hood so i've got fuel and i have spark all four plugs out have spark, GOOD spark, so why no start?
Old 08-31-2010, 10:38 PM
danielsatur danielsatur is offline
Re: 91 si have spark and fuel just no start????
If not timing, how about injectors?
Old 09-02-2010, 10:08 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
There are 3 things you need to start: Fuel, Spark, Compression
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-30-2011, 11:05 PM
Imperial Imperial is offline
^^ agreed, start with checking your compression, you might also want to take a look in the oil filler cap and see if you have any movement. You might have just bad luck and broke your T-Belt.
Old 01-31-2011, 07:31 AM
snshddog snshddog is offline
If the t belt broke there would not be spark but if it jumped afew teeth it will spark at the wrong time. Take off the upper timing cover and line up the mark on the crank, then the top pulley should line up to its mark. Other than that you said you swapped the main relay, did you swap it back? Another test is to spray intake cleaner into it while its turning over, if it starts or almost even, then its probably the injectors not running, Injectors are controled through the main relay, the igniter in the distriburtor, and the computer.
