Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-31-2010, 02:46 PM
killermrob83 killermrob83 is offline
transaxle lubricant
I have a Japanese made '90 Corolla LE with 4A-FE/5 spd manual. How do I find out if it's a C50 or C52 transmission? I called the local Toyota dealership parts department and they could not tell me after running my VIN. The transaxle lubricant called for is 75-90w gear lube. Can I use Mobile1 80-90w synthetic gear lube without causing any problems? Would there be any cost effective results in doing so, or should I just stick with the manufacturer's recommendation? Thank you for your time and consideration. Rob
Old 09-08-2010, 03:20 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: transaxle lubricant
Shouldn't be an issue. The 75- versus 80-weight viscosity is only when the oil is cold. It may feel a bit harder to shift when cold that's all.
Costwise, there is no advantage to using synthetic since the change intervals would be the same. You'd be better off with a semi-synthetic so that you can limit any incompatibility problems with existing seal materials.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
HELP!!! Transaxle removal (it's stuck in the car) babychazz Eclipse 2000+ 1 07-31-2010 05:03 PM
nailing down Transaxle code P0742 bsmith51 Bonneville 1 03-19-2010 03:12 PM
transaxle into neutral eorobe Taurus | Taurus Wagon 6 12-05-2004 11:00 AM
taurus transaxle eorobe Taurus | Taurus Wagon 0 10-17-2001 01:49 PM
Serious transaxle problems! Please help! Josh Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 06-22-2001 02:16 AM
