Old 08-30-2010, 11:13 PM
Leo0365 Leo0365 is offline
97 Buick LeSabre turn signal problem
I replaced the flasher because the left trun signal on the instrument panel just stay on but not flash. The right turn signal is working fine. After replacing the flasher, the turn signal flashes, the left turn light at the front flashes but no light on the rear left. All lights were on when I turn on the headlight suggesting that the bulbs in the rear signal lights are fine. I examined all bulbs and all appear to be in good shape. I turn on the emergency light, no flashing on the rear left truning signal. I checked the fuse box and found no problem with all the fuses. I am now stuck and not knowing what else to look for. Any suggestion will be greatly appreciated.
Leo
Old 08-30-2010, 11:30 PM
inafogg inafogg is offline
Re: 97 Buick LeSabre turn signal problem
i no you checked the bulb but i'd recemend you replace it, but at least ck for 12v
i figure the turn signal is flashing quickly???
thats because the circuits not complete usually a bulb
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-31-2010, 07:32 AM
Thanks Inafogg for the reply. I'll replace the bulb this morning, will let you know whether that fix the problem.
Old 08-31-2010, 06:16 PM
I replaced the bulb and problem solved. Thanks
Old 09-01-2010, 06:58 AM
Note: If the bulb turns slightly black, it should be replaced.
