Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 08-30-2010, 01:30 PM
ArtChee ArtChee is offline
3 of 4 power windows not working
My reliable little 2000 VILLAGER is falling apart this summer. Got cat. converter replaced to solve lack of acceleration problem; replaced VSS to fix erratic speedometer. NOW... 3 of the 4 power windows are not working.
The driver's window works fine, but none of the others!?!?! Searched for a bad fuse, but appears to be no fuse for power windows.
Any suggestions??
Thanks
Old 08-30-2010, 06:51 PM
tempfixit tempfixit is offline
Re: 3 of 4 power windows not working
Have you checked ton make sure the power window lock is not engaged???? Lots of people overlook that.
Also check for a broken wire where the wires go through the door into interior of vehicle.
Did the three windows quit qorking at the same time????
There is a relay for the windows under the dash left side. I cannot find which fuse it is but if the driver window works I would say your fuse is good.
The Following User Says Thank You to tempfixit For This Useful Post:
Punawild (11-17-2012)
Old 08-30-2010, 10:56 PM
Oh, Geez... MOST LIKELY the WINDOW LOCK. Have had the car 3 years & NEVER used it, and not even aware of where it is, but I BET that is the problem. Probably have to get the manual out....
Thanks.
