Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-30-2010, 12:08 PM
ycl1688 ycl1688 is offline
how do I fill in freon for 2001 4runner ?
any clue as to fill freon in 2001 4runner ? Is it the r134 ? I have the hose to fill the freon but no pressure guage. Just one can enough ?
Old 08-30-2010, 12:19 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: how do I fill in freon for 2001 4runner ?
yes it is r-134. There may be a site glass on the accumulator. When the system is full you should see no bubbles through the site glass. Start with one can and see if there are any bubbles.
Old 08-30-2010, 08:57 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
You can get an inexpensive pressure gauge for under $10 that will get you in the ballpark.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-07-2010, 10:27 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you're sure there's a leak, add refrigerant that also includes a dye to help find the leak. Also, if the gauge reads zero when you first connect it, then the system has been fully discharged. Depending on how long it has been like that, you will proabably need to replace the accumulator/drier and apply vacuum to remove all the air inside the lines before adding any refrigerant. This will prevent ice buildup inside the lines by removing all the water that has gotten inside.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
