Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-16-2003, 10:58 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Crankwalk!!!!!
ok i know what it is , its when the thrust bearing goes..
so i have some question about it.. how do you know when you have it.. well the clutch fell wierd..
also if you fix it will it keep occuring?
and what is the permant way to fix it..
thanks
1
Shift_BOOST
97 s14
Old 05-16-2003, 02:03 PM
crankwalk 2g crankwalk 2g is offline
On my car the symptoms were that the clutch would stick to the floor on lefthand turns and the clutch made a clikking sound when pressed down.
You can fix it on a 7 bolt engine but it will happen again, the only permanant fix is to swap in a 6 bolt engine.
7 bolts are in the 2g eclipses and the 6 bolts are in the 1g eclipses.
The best thing to do is swap in a used 6 bolt and rebuild it with performance parts like I did, then it will be bullet proof.
Old 05-16-2003, 02:11 PM
turbo2nr's Avatar
does all 2g's have crank walk?
and any other way of fixing it?
Shift_BOOST
97 s14
Old 05-17-2003, 11:09 AM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Most do but in 98 they switched to a 3 peice thrust bearing. You can just keep replacing the bears but it will keep walking.
