| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
RPM Gage
Does anyone know where I can find info on installing a RPM gage in my 90' Honda Civic DX Hatchback. Thanks allot.
Does anyone know what wire I need to look for?
Thanks |
what kind of tach is it? I hooked mine up to the ignition coil wire, then a wire to ground, a wire to the lights and a power source. My ignition coil was blue, right near the distributor, and i used a little wire splicing clip to splice the tach wire into it.
ok what i did was, if u take off yoru gauge cluster, there is a blue wire in there, thats yoru tach signal wire. so hook up the tach signal wire form the tach to that blue wire. then i spliced into the dimmer switch for the lighting of the tach its right there. then i spliced into my deck acc power line to turn the tach on when i start the car. then of course hook up all the grounds. bam your done
Thanks allot. That was just what I needed to know. Cheers!
![]() ![]() ![]() 6.7 @ 211mph whooping kubo's ass all over the track |
