Go Back   Automotive Forums Car Chat > Ford > Fusion
Old 08-30-2010, 06:41 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
2006 Passenger side mirror
My brother has a 2006 Fusion with the power (not heated) side mirrors. His passenger side mirror got clipped so hard that it pulled the wires out of the terminals in the connector. I took the mirror apart and plastic welded it back together but apparently reversed two of the three wires for the power motors. One of the three terminals still had a small piece of the olive green wire, but the other two had no sign of wire left in them so I had to guess on them. Apparently I guess wrong since when I got it all back together the left to right direction was correct but the up and down was reversed.
Rather than just assume I only need to reverse the red and dark green(?) wires I was hoping someone has a wiring diagram for the car and could tell me which wire should go to which terminal. The rectangular connector does have terminal numbers molded in to it. It's a 4-terminal rectangular connector and my recall is locations 1, 2, and 4 are populated.
-Rod
Old 09-04-2010, 04:15 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: 2006 Passenger side mirror
http://www.fordtechservice.dealercon...440&height=900
-=-=-DANE-=-=-
Old 09-05-2010, 03:19 PM
shorod's Avatar
SHO No Mo
That site has restricted access. Thanks for trying though!
-Rod
