Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-29-2010, 08:58 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
Unhappy 93 Olds 88 random no start and steering binding
The car has 118k on it if i let it sit for a few days and try to start it wont start. Don't hear the fuel pump kick just cranks. I checked the fuel lines and no pressure. leave the car come back 10 minutes later it starts right up. I'm pretty sure its going to be a crank sensor issue but just want some second opinions. Now the steering it only binds when i make right turns and only when the car is moving I have to force the car to turn and force it to go back to center. It makes left turns like a champ so i don't believe its the pump. I was thinking that the rack is bad or something is bent. Anyone have any idea of what the issues could be? thank you!
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 08-29-2010, 09:01 PM
Re: 93 Olds 88 random no start and steering binding
Oh look a thread right below mine with the same no start issues
http://www.automotiveforums.com/vbul....php?t=1040327
I guess ill change the CPS first.
Old 08-30-2010, 11:52 AM
maxwedge maxwedge is offline
A990 racer
CPS has no effect on fuel pressure.
Old 08-30-2010, 05:30 PM
I thought if the CPS didn't send a signal to the PCM the PCM wouldn't tell the fuel pump to kick in.. or is that the fuel pump relay.. if so I've been trying to locate that in my car with no success.
Old 08-30-2010, 07:09 PM
A990 racer
The pump is primed when the key is turned again cps is not in the mix.
Old 08-30-2010, 09:54 PM
So I should start looking at the relay or the pump itself.... I'll change out the relay first just have to find it. I don't know if its under the hood or under the passenger side dash.
Old 08-31-2010, 07:13 AM
A990 racer
Under hood.
