Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-29-2010, 08:22 PM
LieutenantCracker's Avatar
LieutenantCracker LieutenantCracker is offline
99 Hazard Flasher
1999 Mercury Grand Marquis:
Hazard flashers suddenly stopped working.
--> It's NOT the fuse! <--
I THINK the problem lies with the switch-- If I hold it in a certain place between the "on" and "off" positions, they'll flash but I get nothing if the switch is clicked "on"!
All turn signals/bulbs are in proper working order.
Is the switch replaceable... if so, is it a relatively easy fix? (I already know that it's kind of risky working in/on the steering column, because of the airbag);
*PS In case you're wondering: Yes... It IS somewhat more important that I have the flashers working because I use the car in my part-time job, blocking/directing traffic, for various private events. It's not ABSOLUTELY necessary b/c I have other flashing lights (strobes & LED's), but I'd like to have them working, if at all possible.
________
BBW Cam
Old 09-01-2010, 05:47 PM
danielsatur danielsatur is offline
Re: 99 Hazard Flasher
It sounds like you have a little wear & tear on your switch.
Old 09-08-2010, 01:32 AM
Yeah, I agree that's probably the problem...
________
MOTORCYCLE TIRES
Old 09-09-2010, 01:53 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Pull lower steering column trim, there are 2 little torx scerws holding it in, there are 2 wiring connnectors on the back. Takes about 15 minutes to swap.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-09-2010, 02:44 PM
THERE's the answer I was looking for!...
Thanks! (as always, WTO!)
________
EASY VAPE SET UP
