Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-29-2010, 05:59 AM
maliblues maliblues is offline
318 burning oil
I have a few problems here, Have a 97 ram 4wd 318 thats sucking down a quart of oil every couplehundred miles, i started to notice that after i cleaned the throttle body with carb cleaner,it was mucked up good. After cleaning that i also noticed that it idles eratically up and down after startup. Its got 140000 miles and only smokes a little at startup(puff of white smoke)valve seals maybe.Other than that it still runs good.I checked my oil and it looks fine doesnt look milky or anything. I dont know if its a sensor maybe or just coincidence,btw its not showing any codes, so anybody have any suggestions or ideas? Thanks Ron
Old 08-29-2010, 01:20 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 318 burning oil
Pull the back to plugs. If they look asshy especially the passenger rear that the belly pan gasket under the lower intake is bad. Another way to confirm is check for vacuum inside the block. pinch off the PCV breather hose. Remove the PCV valve from the valve cover. Put your finger over the hole with the engine running. If it sucks your finger in than the gasket is bad.
Old 09-10-2010, 06:27 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 318 burning oil
It takes a lot of coolant to make your oil look milky, so I'd do an oil analysis to rule out a bad head gasket.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
