Engine Rattle [solved]
1993 PA 241K miles.
I have a non-specific engine sound that fades in and out (about 5-8 seconds of noise, then 30 seconds quiet, then 10 seconds noise, 15 seconds quiet, etc.,) Tried to use a stethoscope on PS, AC, water pump, alt, belt tensioner but can't pinpoint sound. So far I can't tell if it's only at idle in park or under load while moving as well. I can only hear it at idle in park. I will try to get someone to check it while moving. Sound is not super loud but noticeable and is mid pitch rattle, or kind of like a muted clacking sound (if that makes sense) not real deep or not high pitched and seems to be coming from accessory belt area. Pulled belt off and ran engine, noise goes away. Checked (wiggled) all accessories pulley bearings with belt off and all seem OK (usually bad bearings feel gritty) Thought belt tensioner - replaced it, nope Maybe the water pump but it's new (18 months) and no leak out the weephole and no overheating issues. Put the belt back on, took a 2x2 and pushed up against all the pulleys while running to see if any end play problems - no Thought maybe the harmonic balancer might be separating, but wouldn't the sound still be there with engine running and belt OFF (unless it only rattles under belt tension). Timing chain? I know the mileage is high but engine runs great under all conditions. Just worried I'm going to blow something up. Any ideas? Thanks Last edited by Trio3b; 09-09-2010 at 01:04 PM. |
Re: Engine Rattle
You mentioned that you replaced the tensioner, if your car has an idler pulley I would check or replace it. Had several of these make noise even though they looked okay. Make sure that your belt is good and that it is not missing any pieces on the pulley side. Check the back side of the belt and make sure that there are no signs of heat damage or feathering. Also check for pulley alignment. Your timing chain should be fine if you do not hear noise with belt off.
Re: Engine Rattle
Take the belt off & put both hands on the outer ring of the balancer & turn it clockwise-counterclockwise to see if you can see & feel any free movement.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
| The Following User Says Thank You to HotZ28 For This Useful Post: | ||
Trio3b (12-14-2012)
Re: Engine Rattle
I guess belt tensioner is kind of misleading. I only replaced the belt tensioner pulley and not the whole tensioner and pulley assembly. Not sure what you mean by idler pulley. There are no other pulleys except for the crank, accessories and tensioner. Maybe idler pulley = tensioner pulley? Belt is fairly new with no cracks, feathering or visible wear. alignment seems good. I will also check tensioner mounting bolts and try HotZ28 suggestion about the HB. Thanks |
Re: Engine Rattle
Some vehicles have tensioner pulley and an idler pulley, yours sounds like you just have the tensioner. I know this is in an entirely different spot but, if you only hear the noise with engine loaded at idle, take a look at your heat shielding and motor mounts. To check your mounts, take a long pry bar, wedge it between the engine and some other tough spot like the frame and put a load on the bar and see if the noise changes or stops. You can also take some type of wood and press against any heat shield that you can find and see if that makes a change. Remeber to have the engine running and loaded the same way that you hear the noise when checking. Oh yeah, this just me struck before I hit the reply button, check your alternator. Take it off and go down to the auto parts and have it spin tested. If it is the culprit it will let you now when they get it spinning.
Re: Engine Rattle
Yes it could be your harmonic balancer. In my experiences a balancer will only make noise if it is contacting something while running. The other thing that it will do is make vibration that you are not use to at a specific rpm range. A stock harmonic balancer is usually made up of a crankshaft coupler a rubber ring and the balancing ring on the outside. The outside ring is sandwiched between a rubber oring and the crank coupler. Usually you can tell when you are either going to have a problem or you do have a problem by the look of the rubber in between the two pieces of the balancer. It should be flush with the inner and outer pieces. When it is bad it will be bulging in one place or all the way around. Don't forget to check those mounts and heat shielding.
Re: Engine Rattle
Could it be a timing chain tensioner?
When the belts were off, the rattle was gone! |
Re: Engine Rattle
Accessory drive belts have nothing to do with engine timing belts or chains. The fact that the noise is gone when the accessory belts are off prove my point.
Re: Engine Rattle
Checked heat shield. All OK. Also, noise is at all times, some more some less, but generally all times. Looks like its the innards of the harmonic balancer coming loose. I can see the balancer shimmy when noisy. Worried that this is going to stress out the front main bearing/seal so am going to replace the HB.
The shop manual talks about pulling flywheel cover and using a puller. Is this just to get at the engine to hold it while pulling the HB bolt? Sounds like a lot of extra trouble. I pulled an older Buick Regal HB off years ago and I just left the belt on to provide resistance and then removed the HB bolt and tapped the HB and it came right off as the crank was tapered. Anyone know if this is the same setup on this 93 PA? I don't see any threaded holes in the HB for a puller. Just what looks like a 3/4 or 15/16 center bolt. Also, local salvage yard has HB for $40 as opposed to $150 new from parts store. Is there a way to check the HB? Can I assume that the magnets for the crank sensor embedded in the HB should still be good? Thanks |
Re: Engine Rattle
It's usually balanced for each engine, like speed balanced for wheels!
Re: Engine Rattle
15/16 to get if off, you really should get a new one here. There are some some that need a puller and some years don't, check the how to at autozone .com repair guides, register and the info is there. You will need an impact gun here or as the info says remove the flywheel cover and jam a wedge against the flywheel teeth so the crank won't turn.
Re: Engine Rattle
HB was separating. Came right off but took three tries from local parts store to get the interrupt rings ( I guess that's what the magnet trip is called) right.
Re: Engine Rattle
Re: Engine Rattle
Hotz28 that is an excellent illustration, sounds like a 3 jaw hack job to me.
