Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 08-28-2010, 11:36 PM
chevyg2092 chevyg2092 is offline
92 chevy g20 converion rear air
I recharged my compressor recently. But my rear air does not work. Is there anything I can do to try and get it working again? Like is there some kind of checklist? Need help bad for this one. It's HOT here!
Old 08-29-2010, 08:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 92 chevy g20 converion rear air
Does blower motor and blower motor controls on rear work good?
Any tempt controls on rear unit?
Factory OEM rear ac or add on?
Why did it need recharged?
Leak or AC repair work?
Is front working good?
What is the front vent output tempt and rear vent out put tempt?
Was the correct charge and recharge procedure used?
How muck R-134a used in recharge?
What is the low and high side pressure at idle and at 2 K rpm with compressor running?
MT
Old 08-30-2010, 12:31 AM
ok answers are.... freon resharge - leak but repaired, front works fine, 71 degree output no air rear, im sure the recharge proc. was correct, other than that, i need to get the information again.... will do so asap, lo med high switch on front dash to rear ac no reaction when turned
Old 08-30-2010, 08:57 AM
MT-2500's Avatar
AF - Advisor
You need to get the blower motor working.
Post back low and high side pressure.
How much R-134a used with recharge?
MT
