Old 08-28-2010, 10:42 PM
Ron21 Ron21 is offline
99 Escort ZX2 idling rough
I have a 99 Escort zx2 with about 270 k on it Just reciently it has started ti idle rough. Sometime when stopping for a red light it will idle at 1200 and slowly slow down to 800. Sometime it will idle at 600 rpm and slowly sped up to 800 rpm.The car is a standard with the 2.0 l DOHC engine. The timimg belt was done about 10 k ago.
Any help would be appreciated
Old 09-17-2010, 09:06 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 99 Escort ZX2 idling rough
If you are still working with this problem, inspect for an air leak and check the idle air control valve (IAC). Some people have had luck removing and cleaning/lubing the IAC, or it can be replaced if faulty.
Old 11-01-2011, 03:07 PM
lewis0300 lewis0300 is offline
check underneath the intake manifold. their is a pcv elbow that like to rip causing a air leak, and then check for gasket leaks. That elbow is on the bottom of the IM inside closest to the block.
