Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-28-2010, 10:52 AM
scuddigi_687@yahoo scuddigi_687@yahoo is offline
EST Wire and best time setting!
Hello everybody, I gotta 93 chevy caprice can anyone show me the exact spots and or picture of this est wire is located and the engine is 350tbi swapped from a 94g30 van Ive been at it for days and I've been told it could be in multiple spots still got the same wire harness for the caprice. Original block was a 305. Also wat is the best considered time setting for this type of motor, thanks!
Old 08-28-2010, 12:50 PM
Re: EST Wire and best time setting!
why is my question locked what does that mean I sen ppl viewed it what is goin on?
Old 08-28-2010, 01:06 PM
463's Avatar
463 463 is offline
not locked on my screen
Old 08-28-2010, 02:09 PM
CD Smalley CD Smalley is offline
EST wire should be on the passenger side fender well or on the firewall on that side. It's a single wire. Brown with a Black stripe.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-28-2010, 08:15 PM
cd smalley I looked for exactly two hours in the direct sunlight no go I know the color but do I cut it then wrp it together also there are a bunch of wire over there...none of them with a connector!
Old 08-28-2010, 08:29 PM
No need to cut it. There is a weather-pack connector on it.
Should be located on the engine wire harness, next to the left valve cover (watching engine front) next to the air injection control valve.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-29-2010, 12:02 AM
I ain't the smartest ant in the candy wrapper but what is a weather pack?
Old 08-29-2010, 12:51 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
It's the type of connector that GM uses on its wiring harnesses.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-29-2010, 02:23 AM
I see that but what does the weather look like? I'ma try to find it again tomorrow you gotta pics of it? And when you say air injection valve do you mean the IAC motor?
Old 08-29-2010, 10:34 AM
Blue Bowtie's Avatar
Registered Offender
I believe he means the A.I.R. diverter valve. This is the valve which controls the flow of air from the air injection pump to the exhaust manifolds.
A WeathPack connector is a type of electrical connector designed by the Packard Electric Division (you'll often read "PED" on the body of these connectors) of General Motors. They are now sold under the Delphi name and many other auto manufacturers now use them because they are a superior design. The connector you need to find is a single wire connector looking something like this:
Old 08-30-2010, 01:59 PM
burnM's Avatar
burnM burnM is offline
EST - The same connector as in the picture above, but for a 305 check beside the throttle body over the intake manifold on the passenger side. That's where it was on my '91 Caprice, although the casing was a different colour.
As for the timing, I would like to say 4deg. BTDC? However, what I like to do is set up a vacuum gauge and set the timing with that.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 08-30-2010, 08:03 PM
I think 0* is what you'll find on the emissions sticker. I personally have played with 0-6*BTDC in my 89. 4* probably gives a slight SOTP boost. But I had pinging issues at times with 4* and had to go back to 0*.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
