Old 08-28-2010, 01:05 AM
9901gp 9901gp is offline
Rim bolt pattern off set
Im thinking of getting rims for a 99 gp. I know the bolt pattern is 5x115, Will it work with a 35mm offset? thanks
Old 08-29-2010, 08:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Rim bolt pattern off set
Which model GP do you have or wheel size? What wheel size do you plan on using so the answer may vary depending on wheel size.
For example the stock wheel offset for '97-'03 GT or GTP models with 16" factory wheels is around +52mm offset.
Timeslip 08/12/06
AF Community Guidelines
Old 08-30-2010, 08:09 PM
My mistake, they are going a 99 GTP rim size is 18x8.5 bolt pattern 5x115 with a 35mm offset, tire size is 245/45/18
Old 09-03-2010, 11:45 AM
BNaylor's Avatar
I have AR Casino 18" wheels (8" width) with P245/45/18 Goodyear Eagle RSA tires on my GTP and the wheel offset is 42mm positive. 35mm may work but the best thing to do is have it test mounted and check to make sure nothing is hitting the braking components. Good luck.
Timeslip 08/12/06
