95 pont bonn sse just stalls
ok have a 93 bonn sse it stalls just going down the road pull over and hit park and it will crank right back up so cant see if it losing spark or fuel but just change fuelpump and still does it
Re: 95 pont bonn sse just stalls
You will need to look deeper into this issue...
If the PCM has a drop out from the crank sensor, even for a split second it will stall out... Its hard to work through an intermittent problem... Check the codes and see if you have anything stored in the PCM... |
