Old 08-26-2010, 07:28 PM
jlc55's Avatar
jlc55 jlc55 is offline
HVAC air distribution problem
have a 1998 jeep cherokee with six cyl engine..sometimes when in driving on the highway about 60-65 mph the ac suddenly comes out of the defrost vent then i lift the gas pedal and it goes bk to normal on the ac vents..what could b happenin..any suggestions would help....thanks!
Old 08-26-2010, 09:19 PM
old_master's Avatar
Advisor/Moderator
Re: HVAC air distribution problem
Vacuum leak in the HVAC system. Could be a faulty check valve or leak in the reservoir, or a vacuum line is leaking somewhere between the source, (intake manifold) and the actuators in the dash.
You have to know how it works,
to figure out why it doesn't.
Old 08-27-2010, 08:21 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Concoured with vacuum leak.
Old 08-27-2010, 02:38 PM
mastertech1964 mastertech1964 is offline
yep definetly a vacuum problem with the lines or the canister itself
Old 09-02-2010, 10:11 PM
xj31 xj31 is offline
Look by the battery,the plastic vacuum line gets melted by the battery acid
