Old 08-25-2010, 07:12 PM
Eagle88 Eagle88 is offline
Question 97 voyager several problems
1 no dash lights. I checked all fuses, is it possible all the bulbs could be burned out?
2 Heater fan works sometimes, as far as I am aware the fan motor is good, is there a relay or something other than what is in the fuse panels?
Old 08-28-2010, 03:45 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 97 voyager several problems
1 - Check the instrument cluster connector. Not likely they all blew at the same time.
2 - Next time the blower doesn't work, check for 12vdc at the blower motor connector. If it's there the blower is toast. If it's not it could be the blower resistor block/control module, panel switch or wiring.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
