Old 08-24-2010, 12:59 PM
sharpie22 sharpie22 is offline
2000 GT window issue
So i just replaced the switch on my window because it was going out intermittently, then to full power. Well, didn't solve the problem and now I'm wondering if the motor is bad on the window. My window will work fine about 50% of the time...then the other 50% it wont roll up period. But the weird part is that I can resolve it by tricking my car. If i park, turn it off, open the door, lock it, unlock it, reopen the door and then turn it back on again...it will work . Any ideas?
Oh and btw the aftermarket switches from ebay suck...bought one and in order to go down all the way you just have to "hold it down a bit longer than a quick tap". OK...so now it is rolling all the way down and I can't stop it halfway otherwise it will stop, and when i release the button start going back down again. Whoever thought of these was an idiot...so now i am stuck with buying a new switch or rolling all the way down and then halfway back up every time .
Old 08-24-2010, 01:06 PM
saturntech's Avatar
saturntech saturntech is offline
Re: 2000 GT window issue
check the wire harness that runs through the door to the body, most times there are broken wires in there.just remove the rubber around the harness to get a good look. If wires are all ok then most likly it is a window regulator
Old 08-24-2010, 01:15 PM
I will check the harness, but wouldn't the window regulator either function/not function? I didn't think that could cause an intermittent problem. That is more mechanical than electrical if i'm not mistaken.
Old 08-24-2010, 01:46 PM
saturntech's Avatar
Most time yes, but I have seen in some cases that the motor was intermittent.
Old 08-24-2010, 02:59 PM
exactly what I was thinking...think i might replace that motor this week whenever i get a chance. i'm sure that will be fun...
Old 09-03-2010, 09:18 AM
Well I replaced the motor only to realize that there were 2 problems associated with the window. 1. The motor was very worn out and slow/needed replacement. 2. The switch that I got from ebay crapped out on me in the month that I have had it. I have a new switch coming warrantied in the mail right now.
My question is...currently my window is down and my switch finally fried out on me. Is there a way to connect a couple of those pins on the set of wires that connects the motor to the switch in order to roll the drivers window up?
Old 09-04-2010, 06:24 PM
Really? No one knows how to short circuit the wiring in order to cause the window to go up? I know there is a strategy to connecting a wire between certain holes in that harness...unfortunately being a mechanical engineer I don't know *(&^ about electricity. I appreciate your guys help...thanks.
Old 09-05-2010, 10:01 AM
BNaylor's Avatar
BNaylor BNaylor is offline
To start you do not short circuit any wiring to make the power window drive motor do its thing. The drive motor uses two inputs. 12 volts and a ground. It is polarity based. Depending on polarity the motor either goes up or down. Just trace out the wire color coding from the switch assembly connector and harness to the respective drive motor at the door panel assembly. Follow to the pins used. You can apply the 12 volts and ground there or direct at the drive motor connector which should have two male pins using small alligator clips.
Note: If the motor doesn't move switch/reverse positive and negative which will reverse polarity.
Timeslip 08/12/06
AF Community Guidelines
Tags
motor , switch , window
