Tire Preasure Light
I have a 1997 GP GT 210,000 miles and still running strong thanks to a lot of help from this forum and the regulars who post here, Thank You
.My tire pressure light is on and i am not sure why? I have checked the tire pressure with three gauges and had the guys at the garage down the street check and all say 33-35 psi on all tires. I then ran over to oreilly auto parts to use their code reader to see if i could tell if a wheel bearing unit was bad and the code reader said there were no codes to pull. I guess i am not sure where to look or what to test next, any ideas? Is there a sensor on the wheel i should or can check? |
Re: Tire Preasure Light
do you have a reset button for the light down near the drivers kick panel?
And the o'reilley's scanner won't be able to scan for a bad hub.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Is that the yellow button?
yes, thats it. hold it until the tire pressure light blinks
That little yellow button did the trick. I had always wondered why that button was there. Thanks for the help guys.
