Old 08-23-2010, 08:27 PM
HeWhoKillz HeWhoKillz is offline
death upon acceleration
What causes a car to die when you give it gas? This pertains to an 89 century but I figured it was a general question.
Also, if you have bubbles in your coolant resevoir and you know it doesn't need bled, is there any method of finding where the air is getting into the cooling system? This is for my 91 corolla which still has this problem, I just haven't driven the vehicle in months.
Old 08-24-2010, 05:25 AM
maxwedge maxwedge is offline
A990 racer
Re: death upon acceleration
Low fuel pressure, clogged fuel filter is the most common on the Buick.
Old 08-24-2010, 09:05 AM
is there a way to adjust the fuel pressure?
Old 08-24-2010, 06:52 PM
A990 racer
No. Either regulator is bad, the pump is bad or the filter is clogged, assuming the pressure is low when tested.
