Old 05-15-2003, 02:34 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Phase Two complete (updated)
well i got my new wheel mounted and put on today... and i also installed my braided stainless lines... it has been a productive day! pics and a write up on the lines will follow... well here are some picks but i'll write up a "how to" for them later.. seeing as how i could find none.... it was relatively easy to do though...
the wet stuff is mainly WD40, and then some brake fluid...
Tools/materials needed,
Brake line set
1 quart (one big en or two little) bottles of your choice in brake fluid
10, 12, 14 MM socket and rachet (3/8 will work fine 1/2 is nice too)
8, 10 MM wrench
Torque wrench is nice to have but not completly neccessary
jack and jack stands
Basin tub
Pliers, and maybe a screw driver...
First thing first... if you have the capability to jack the car completly off the ground it makes life easier. So jack it up and support it well with jack stands! Pull off all four wheels and set them aside.
Ensure that the M/C is full with Fluid and check it as you complete each corner.
Spray every thing liberally with a lubricant such as PB Blaster or WD40
Loosen up the joint fittings and retighten them just enough to keep fluid from leaking out (this is where the 1/2 rachet comes in handy for the 14 mm on the caliper) be careful to not snap the upper 10 mm one though!
Once you have the fittings broken free, move on to removing the remaining brackets.
With the hose free, you now place a drip pan below where you are working, DO NOT TOUCH PAINT brake fluid eats paint, with that in place I then completly removed the bottom fitting. You know the one that attaches to the caliper. Move it out of the way, I hung mine up on the upper control arm.
Moving on to the upper joint, its easiest if the clamp is left in place, just use your 10 mm wrench and unscrew the the threaded nut. Once it is free grab the pliers and grab on to the little tab of the clamp
Once out the line will just pull thourgh.
To install follow the directions but in a reverse manor, i.e. put the line up through the hole and insert clamp...
also be sure to put a banjo washer on both sides of the bottem joint
and it is supposed to be torqued between 12-24 psi, I took mine to about 20 for good measure... but I think you could get away with out a torque wrech, be careful though!
Now for the rear, there is much much less work... but its in a tighter space.
these are all the tool needed!
All you do is loosen each end, pull the pin swap lines, tighten and reinstall the pins! Its a lil easier said than done do to space though. and the lack of the pins on one side of my car, grrrrrrrr stupid people!
the final step is to bleed the brakes, make sure you do this properly according to your manual and do not drop the pedal to the floor, it may result in a master cylinder failure!
whewwwwwww I think that covers every thing. I rate this job as a 5 out 10 on difficulty, mainly due to bleeding of the brakes.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 05-15-2003, 07:22 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
nice write up man, they look good, know imma have to do that on my whip.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-15-2003, 07:35 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
how does your pedal feel? more responsive?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 05-15-2003, 08:27 PM
thanks,
and yeah the pedal feels soooo much better now, its a lot firmer doesn't drop like it used to, and finally the harder i push the harder it clamps yay! i like it! well worth the green...
Old 05-15-2003, 09:05 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
how much did it cost and where did u get it from ? i think i should get some now
Team Lonely Drivers
Old 05-15-2003, 09:45 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
after all these little fixes...what is still left? you excited over all the work?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-15-2003, 10:47 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I should do stainless lines on mine someday...i only have about 10 things i "should" do to mine.....but not enough money to do them all right now....hhehehehehe
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-16-2003, 12:22 AM
the kit i got was 120 plus shipping from tire rack... i've saw them on the groupbuycenter.com for a lil bit cheaper... but i was already ordering a tire so i figured what the hell and got them too... and i got a few more annoyances left... like the hood, i need to replace it, i recently got this tick from hell that seems to have no orgin, all i know is is only happens on throttle (me thinks its an injector) and i need to figure out why in the hell i'm running so rich... is there any friggen way to lean our cars out? and no i'm not getting any codes, and the timing is dead on... other than that... well the frame is still bent and needs straightend... but hey ya know can only fix so much at a time...
