Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 08-23-2010, 10:20 AM   #1
lesabrefan
1996 Overheating, all coolant in expansion tank
On a hot summer day last week, the car overheated. All the coolant was overflowing from the expansion tank and light smoke coming from the engine, so it seems like the engine is not receiving any coolant. Did a flush over the weekend, replaced the coolant. Same thing is happening again. I thought it was the water pump, but there're no leaks from the pump and no noises either.
What in the world is going on?
Thanks, guys.
1996 Lumina 3.1 - 191K
2001 LeSabre Custom - 153K
2006 Explorer 4.0 - 55K
lesabrefan is offline   Reply With Quote
Old 08-23-2010, 10:51 AM   #2
McLin
McLin's Avatar
Re: 1996 Overheating, all coolant in expansion tank
Maybe the radiator cap is leaking air.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
McLin is offline   Reply With Quote
Old 08-23-2010, 11:11 AM   #3
lesabrefan
When i unscrewed the cap today, it made a loud sound and the coolant began to flow back into the radiator from the expansion tank. So i believe the radiator is pressurized correclty.
Old 08-23-2010, 11:26 AM   #4
McLin
McLin's Avatar
Bad radiator cap
The radiator cap does several things. It
seals the system against the outside world (main seal function)
keeps the system pressurized when needed, so as to raise the boiling point of the coolant
allows excess pressure and coolant expansion to vent to the expansion reservoir (pressure seal function)
allows coolant to return to the radiator when the engine cools down (return seal function)
As you may have gathered from the above section, the radiator cap has three seals, any of which may fail independently of the others:
The main seal is the one that seals the cap against the top of the filler neck. Just a rubber gasket that operates just like one on the lid of a pickle jar. Simple and reliable.
A failed pressure seal will allow the coolant to boil at a lower temperature, and coolant will be able to travel freely and foamily to the expansion reservoir. This will cause localized hot-spots inside the engine, which can lead to premature head warpage, and may hasten head gasket failure. It will also cause the rad coolant level to be low, just like a failed head gasket.
A failed return seal will prevent the coolant from returning to the radiator as the rad cools off, causing a vacuum that can collapse the radiator's hoses. This will prevent the coolant from circulating if the hoses don't re-expand as the engine warms up.
A bad rad cap can cause similar symptoms to a failed head gasket, so it's a cheap first step to try before bringing it in. If you replace the rad cap and you still have bubbles in the coolant (or foam in the reservoir), then suspect the head gasket.
If the engine starts to overheat at idle, or in heavy traffic, and the gauge goes down when you rev it, the coolant is probably low.
Moreover, a neglected cooling system can load up the cap with crud and corrosion, preventing proper coolant flow in and out through it. Peel the seals back with your fingernail to check for goop. If you find any, a blast with a garden hose and probing with a toothpick should clear most of it out.
But anyway, a new rad cap is less than $20. Make a habit to change it every 5 years, just in case. It's pretty important.
Source
Best regards McLin.
My Lumina
Mileage:
Old 08-23-2010, 12:43 PM   #5
lesabrefan
Excellent, will start with that.
Thanks alot for your help
Old 08-25-2010, 01:54 PM   #6
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Thermostat may be shot too...also did you bleed it correctly after refill?
Were the fans running when it overheated? Does it overheat when moving, sitting still, both?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 08-29-2010, 02:51 PM   #7
ladagosta
ladagosta's Avatar
Thanks, guys.
did you resolve this issue with the overheating?
I am still working on mine and even though everyone says not likely to be the water pump unless my radiator is clogged it has to be the water pmp gone bad or not circulating enough.. still working this out.. after overheating issue began 2 years ago.. finally broke down and replaced LIM gasket and after that still had over heating issues.. have replaced thermostat with a failsafe so that removes the t stat from being the cause .. no water from exhaust not even a slight bit of moisture.. no evidense of water in oil or oil in coolant.. so it is not the head gasket.. out of causes other than the water pump.. or a bubble in the hose with is highly unlikely..
ladagosta is offline   Reply With Quote
