Old 08-23-2010, 09:05 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Water Pressure
Kind of off the wall question...
The water pressure at my apartment sucks. It sucks so bad, that when I try to use my hose outside, it doesn't spray far (that's what he said). I want to wash my car port down since it's filled with oil and coolant and gas, and use that driveway cleaner stuff, but I really need water coming out a little harder. Is there a way to adjust that or make it better? It's not just the outside hose (although probably the worse from everything); the shower and sinks kind of suck too.
Any fixes for that?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-23-2010, 03:31 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
Re: Water Pressure
Any fixes for that?
aside from using a pressure washer outside
products from this site are VERY good, kinda expensive but worth it.
I had horrible water pressure at my last house and bought the shower head off this site and was really surprised with the change.
give it a try
http://www.takeashower.com/
Old 08-23-2010, 03:46 PM
david-b's Avatar
Dave is THAT guy
Re: Water Pressure
Very nice. Def something to consider. I rent for now, so I'll stick with my current head until it needs replacing.
For outside, I can't even water my grass it's that's bad.
75 Monte Carlo
Old 08-23-2010, 03:56 PM
Re: Water Pressure
I rented to, you could just do what I did and replace the head, then when you move put the old one back on and take the good one with you.
Also, there is some as seen on tv water hose thing I remember seeing a while back, supposedly it turns any outdoor hose into a pressure washer.
Old 08-24-2010, 10:13 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Water Pressure
You can check to see if the valve on the water main going to the house is all the way on.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-24-2010, 12:24 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Water Pressure
Hey Dave,
Second the notion to just use a pressure wahser. Low water pressure throughout the entire building is indicative of mass plumbing problems should the main valves not be open all the way as silver suggests above.
Old 08-24-2010, 01:14 PM
david-b's Avatar
Dave is THAT guy
Re: Water Pressure
I would if I had one, but like I said, I would like to water the grass and wash the car once in a while at home.
Where can I find this main valve you speak of? Guessing in the basement somewhere?
75 Monte Carlo
Old 08-24-2010, 01:41 PM
Holset powered 420a
Re: Water Pressure
Its usually out by the street.
98 Eclipse GS Turbo
2001 BMW 325i - DD
