Go Back   Automotive Forums Car Chat > GMC > Savana
Old 08-23-2010, 08:48 AM
mad max mad max is offline
2005 Savana 3500 360 V8 - sticky(?) heat/cool control setting
Having problems with heating and a/c (blue-to-red heat/cool control dial) vent operation.
Previously this was found to be a block with a bunch of hoses under the passenger dash that had a small clear vacuum hose disconnected. Reconnecting it made the heat/cool control work again. But within the last year or two I've noticed that come winter of fall and I change the setting from heat to cool, or cool to heat, the vent(?) seems to stick for a while and then while driving on the highway in blaring heat or freezing cold, poof:the thing finally decides to switch over to the right condition. Winter is around the corner and it's stuck in cool again, which also obviously makes trying to control/fine tune the temp with the blue-to-red heat/cool control dial useless.
What would you think might be causing this problem: where should I look?
Thanks,
Mad Max
