Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-23-2010, 01:52 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Mechanical Water Temp Gauge
I'm wanting to install a Mechanical Water Temp Gauge. My '99 CVPI has the aluminum crossover at the front of the engine, I'm thinking about drilling and tapping there for the sender bulb. Has anyone tried this? Is there an alternate location to get a good temp reading on the 4.6 head? My gauge has 6' of tubing from bulb to gauge. I plan on mounting it on the "A" Pillar.
Thanks
Stale Trooper
Old 08-23-2010, 08:05 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Mechanical Water Temp Gauge
There should be a circular point on the opposite side of the aluminum crossover of the ETC sensor. Drill and tap in that circular area, and you will be safe. This is the location where the second sensor used to be located in earlier 4.6L engines (when 2 sensors were used) so it is an accurate reading.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 08-24-2010, 11:35 PM
I have thought about that spot, but with a 6' long bourdon tube, I think thats too long of a reach from the "A" pillar. I read of a plug in the side of the block on the drivers side, that some guys have mounted an electric sensor for a gauge; I wonder about just extending and adapting to that spot for my mechanical unit? Of course, it would have to be insulated to read correctly. but that shouldn't be a problem.
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
