Old 08-22-2010, 01:32 PM
RATmotorsports RATmotorsports is offline
2000 ZX2 Fuel, Temp and Tach quit working
What could cause the Fuel gauge, temperature gauge an Tach to stop working. The fuel gauge started jumping around between a 1/4 and 1/2 then the low gas light would come on with the gauge at 1/2. Now it is stuck on 1/2. The tach and temp gauge just stopped within 1 day of the fuel gauge acting up. Any suggestions?
Thanks
Old 08-23-2010, 08:50 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 2000 ZX2 Fuel, Temp and Rach quit working
Have you checked the fuse?
Nevada Tumbleweed
Old 08-24-2010, 09:44 AM
Davescort97 Davescort97 is offline
Escort guy
The tach, fuel gauge and temperature instruments operate off of the same circuit. I suspect a faulty ground. First off, it is a long shot, but clean and tighten the ground terminal on the battery and check the ground connections down stream of the instrument cluster.
Old 08-24-2010, 07:48 PM
Tumbleweed: didn't think it would be a fuse the way the fuel gauge was jumping around at first but I will check that.
Dave: I will also check that.
Thanks Guys!
Old 08-25-2010, 09:03 AM
Thanks Guys!
Your right RAT. After re-reading what you wrote I agree the fuel gage would have completely quit
Nevada Tumbleweed
