Old 08-21-2010, 06:21 PM
fxrmike fxrmike is offline
power steering whines
power steering whines and is hard to steer after driving for a while. Let it cool and it stops whining. Any suggestions
Old 08-22-2010, 03:30 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: power steering whines
Model year?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-22-2010, 12:26 PM
danielsatur danielsatur is offline
Flush pwr steering fluid , and go wih fresh fluid
Old 08-22-2010, 08:28 PM
It's a 98 caravan. I'm going to try to flush and refill. How is the best way to drain the old fluid?
Old 08-22-2010, 09:23 PM
TCGrove TCGrove is offline
I've done this twice on my 01 T&C. The fluid breaks down enough that it causes a lot of whining. I just took a bottle and put two tubes in the top (by cutting holes in the plastic cap). I used it to suck the fluid out of the fill/resevoir. Some people use a turkey baster. You may have to flush it a couple of times, but it works.
Old 08-22-2010, 10:19 PM
troy1 troy1 is offline
AF -Advisor
Look at the screen in the reservoir and make sure it not plugged up with junk
Old 08-23-2010, 02:18 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Reason I asked for the model year is I believe starting with the 4th generation vans (2001-2007) Chrysler introduced a reservoir with an integral fine mesh screen filter that easily cloggs creating whinning. Not your case. Best way to change fluid? Some disconnect the pump output hose. Most just drain the reservoir a few times using the tried and true turkey baster. I like the turkey baster. Much easier on the back. Just drain and fill then drive it a bit, repeat two or three times. Too busy? Drain and fill consecutive weekends.
