Old 08-21-2010, 12:24 PM
shy07014 shy07014 is offline
'98 Speedometer not smooth, jumps every 5 mph
Just bought a '98 cargo astro with 130,000 miles, and it runs superb. The only issue is that the speedometer is not smooth. it gives a pretty accurate reading when accelerating and cruising, except that it jumps every 5mph...however when braking its pretty off, also going down it skips about every 5 mph...any ideas?
Old 08-21-2010, 01:03 PM
old_master's Avatar
Advisor/Moderator
Re: '98 Speedometer not smooth, jumps every 5 mph
Check the VSS, (Vehicle Speed Sensor) on a capable scan tool. Watch for smooth operation, (no spikes) while accelerating and cruising. If you don't have access to a scan tool, check the connection at the sensor, (located on the tail housing of the transmission), it might be loose or corroded or the VSS might be faulty.
You have to know how it works,
to figure out why it doesn't.
Old 08-21-2010, 02:44 PM
thanks alot
