Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-21-2010, 08:44 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Over-torqued bolt what to do?
Hey guys,
When installing my water pump I over-torqued one of the bolts thanks to a faulty torque wrench and ended up shearing off the bolt head. It's not a big deal right now because the pump is working properly with no leaks. However, if and when I need to replace the pump, how do I go about removing the bolt shank?
Thanks,
Alex
Old 08-21-2010, 09:27 AM
j cAT j cAT is offline
Re: Over-torqued bolt what to do?
Originally Posted by ASJT3 View Post
Hey guys,
Thanks, Alex
since this is just a bolt that broke due to over torquing here in this application and the threads are not damaged stud not bottomed out , you should have no problem removing with a 1/4 inch REVERSE drill bit. then as the bit cuts into the stud the bolt will unscrew.
Old 08-21-2010, 09:58 AM
Great thanks I'll keep that in mind next time I open 'er up!
Old 08-21-2010, 04:52 PM
Blue Bowtie's Avatar
Registered Offender
Which bolt? If it's one of the four longer bolts mounting th epump to the block you should be able to remove the remaining three, slide off the pump, and remove the broken one with a good pair of pliers (notice I didn't suggest Vise-Grips, but a GOOD pair of pliers).
