Originally Posted by mrhab68
Does anyone know what will run rats out of air conditioner ducts. I have a 2003 1500 HD Silverado crew cab with dual automatic climate control. First they built a nest on the engine which caused a fire with a good bit of damage to the wiring & fuel rail. Where does the havac system take in fresh air at? If I could find this I would put some kind of screen over it. I have had to drop the blower motor 3 times to clean out the rat nests. I would like to run them out before blocking the entrance hole. This truck is not driven every day is one reason they have to it. Any help would be appreciated. I have about decided this truck is jinxed. I had it less than 2 weeks when a deer done $4500.00 in damage then the fire was $2000.00 now rats in the air vents.
remove the blower motor, then install the 1/4inch mesh heavy duty rat screen/wire mesh. remove the wipers, then the air intake screen , look for entry areas and block with this screen.
buy some rat posion green blocks, cover with peanut butter and place under the hood in a good spot. you have to kill those rats that have found your vehicle a good place to live , they will come back if not killed..
