Have a 98 dodge grand caravan..Battery went dead..someone gave me a jump and now the headlights, dashboard or interior lights will not work. Does anyone have any suggestions? I don't know if it is just a fluke that it happened at the same time or what. I have already checked the fuses and I do not see anything that looks like it is burned out. Please help! thanks in advance.
Re: No headlights, dashboard lights or interior lights
Common denominator is the Body Control module (BCM). Try disconnecting the negative battery cable for 2-3 minutes then reconnect. This will reset the BCM.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
Thank you so much for your HELP! We did go out and took off the negative cable on the battery let it sit...and it WORKED! Thank you so much Again!
You're very welcome. If you took it to a shop there'd be a good chance they would have changed the BCM and charged you $500+. Still may come to that. Sometimes the reset trick is only temporary but can be permanent. Thanks for posting the fix.
