Old 08-20-2010, 08:22 AM
hamricks99 hamricks99 is offline
Unhappy loss of power while driving engine doesn't shut off and idles fine
2000 inifiniti G20 - Car idles fine, gears engage fine, clutch is not hard to depress, no slippage.
However, car has a complete loss of power, seemingly returning to idle even while driving.
I can floor it while in gear and get NO power...just idle it seems but when I down shift it will rev up.
A mechanic has looked at it for three week he claimed it was NOT the clutch or MAF Sensor. Replaced O2 sensor.
Dealership just charged me 125 to say it was the clutch and master cyl....
But this makes no sense to me.
Old 08-22-2010, 10:33 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: loss of power while driving engine doesn't shut off and idles fine
Welcome to the forum!
You might have better luck posting this to the G20 forum. For starters though, has the shop you had look at it pulled spark plugs, checked for diagnostic codes (pending or current), or checked the fuel pressure? When's the last time the car had a tune up?
-Rod
Old 08-23-2010, 07:43 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Ditto with getting better results in the Infiniti forum. It sounds as if you have a manual transmission so that eliminates many potential problems with shift solenoids and problems within the valvebody. But to me it sounds like it could be either a speed sensor, throttle position sensor, faulty O2 sensors, or even possibly a engine temperature sensor.
Find a place to scan your codes for free (auto parts stores) and post back here if you don't get a better hit in the Infiniti forum.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-11-2010, 03:31 PM
bobmartin888's Avatar
bobmartin888 bobmartin888 is offline
First Check all basic items
Plugs, wires, fuel pressure, vacuum lines, pcv, air filter, etc. as they apply to your car.
then one thing is check you catalytic converter, a plugged cat can cause a no power off idle situation!
_________________________________
I'll put mine in!
'10 scion xD, Stock!
Old 09-11-2010, 11:11 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Check your catalytic converter .
" Sometimes I grow so tired "
