Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 08-19-2010, 12:06 PM
richamer1 richamer1 is offline
Send a message via Yahoo to richamer1
ABS light
00 A4 Quatro. Recently my brake light and ABS light come on together randomly. Then they go back out after a little while. Any thoughts ?
Old 08-19-2010, 06:40 PM
danielsatur danielsatur is offline
Re: ABS light
Clean your wheel speed sensors + connections.
Old 08-19-2010, 07:50 PM
AutoService101's Avatar
AutoService101 AutoService101 is offline
Re: ABS light
If that does not help you may have a possible bad ABS control module. I believe this was a common issue with these vehicles. I suggest having someone scan the computer and check your codes. If this module is bad it is pretty expensive to fix, about $1500 I believe.
Visit my blog at : http://automotiveservice101.blogspot.com/
Old 08-20-2010, 08:54 AM
Re: ABS light
Can I get a little more information on cleaning sensors ? Are they mounted near the calipers ? Are they obvious when you pull the wheels ? Thanks
Old 05-16-2016, 05:45 AM
qaw010203 qaw010203 is offline
Re: ABS light
I get this issue too :/
check out Servicing Stop as they fix anything and everything to do with cars and have a brilliant service, they pick your car up, fix it and drop it back off! Plus 50% off your service!
Old 05-17-2016, 09:26 AM
peter123wallace peter123wallace is offline
Re: ABS light
Same here :/
