Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-18-2010, 09:49 PM
dapopes's Avatar
dapopes dapopes is offline
vacume problem on 95 GM?
My mech said reason for a/c cutting in and out has to do with vacume deficiency. He said prob could be behind dash or behind pass side front fender. Anyone have any history with that?
Old 08-18-2010, 11:36 PM
danielsatur danielsatur is offline
Re: vacume problem on 95 GM?
Do a Google ''youtube auto smoke machine''
Old 08-19-2010, 09:12 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Do you have the Electronic Air Temperature Control (EATC) unit? If so, the vacuum solenoid o-rings are probably dried out and need to be replaced. When vacuum is insufficient, it will default to the defroster position.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 08-20-2010, 04:19 AM
dapopes's Avatar
Thanks for the replies. Your right, it does revert to the defrost position. Where would the "EATC" be if I do have it? Sorry to sound so ignorant!!!!! Btw,could a vacume deficiancy cause spongy brakes?
Old 08-20-2010, 09:53 AM
If you have a vacuum leak significant enough to affect brakes, the brakes would become hard, not spongy. And he engine would likely run like crap.
An you have an EATC, you will have the digital thermostat controls. The one where you set the temperature you desire and it can control everything for you. If you do not have the EATC, you have three knobs instead - temperature, blower speed, and where you want your air coming from.
Here's an abundance of information about the EATC and some pictures comparing the EATC and manual controls.
http://p71interceptor.com/eatcswap/
Old 08-22-2010, 10:49 PM
dapopes's Avatar
Thanks for the info. No I guess I don't have the EATC.
