Old 08-18-2010, 02:24 PM
javatrooper's Avatar
javatrooper javatrooper is offline
auto shutdown relay?
Just swapped 4.0 engines into my 93 sport from a 92 Larado. Went to start. Heard relay clicking. No start. Thought it was fuel pump first. Bled fuel line to get fuel to rail. Still clicking, thought it was fuel pump relay, swapped, still clicking, pulled fuel pump relay out, turn on key, still clicking. I think it's my auto shutdown relay.
What would cause this relay to click? Haven't checked for spark yet, have to wait for wife to get home first, but I have no idea what caused this relay to click.
Also forgot to tighten my block to firewall ground bolt on head, so had to fabricate a ground from front of head to firewall using 3 electrical wires, but should be fine for ground connection.
Any thoughts?
Old 08-18-2010, 03:04 PM
Re: auto shutdown relay?
update, I have no relay in the auto shutdown. the clicking relay is coming from the starter relay. Starter works fine though. Still no start.
Old 08-18-2010, 07:06 PM
rhandwor rhandwor is offline
Check for a lose battery terminal and check voltage on battery.
Old 08-18-2010, 10:03 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
When you say "no start", does the starter turn the engine over?
Did you use the starter that you had on your vehicle before the swap, or the one from the donor vehicle? If it's from the donor, it might have sat for a long time and be frozen up.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-19-2010, 12:36 AM
Starter is cranking the engine. I don't have spark at plugs. Do have spark at coil. When my engine was up-side-down there was oil on my distributor, so I looked inside and there is oil there. Thought maybe my cam position sensor got oily so swapped in the dist that I drove into my garage with. Still no spark. Did put on new cap and rotor. Next move is to reinstall old cap and rotor. Also for sure not 180 degrees off.
Not sure where to go after that. Can swap ecu, crank position sensor. Would like to think I could figure it out without swapping everything, but then again that's the beauty of having a parts car. Is there a logical order to check the spark out?
thanks
Old 08-19-2010, 12:37 AM
as far as the auto shut down--I got. Just have to look at the chart right side up.
Old 08-19-2010, 05:50 AM
thanks
If the coil sparks and it doesn't get to plugs. Ohm the wire from the coil to the distributor cap. If it reads approximately 1/2 scale clean the distributor cap. Next check if the rotor is turning. Clean inside the distributor cap.
Replace if you can't find the problem.
Old 08-19-2010, 11:49 AM
Don't forget you might need new plug wires also.
You said the engine was upside down. Oil may have gotten into the cylinders and fouled the plugs. So I'd replace the wires and plugs as well, and check for spark before putting in the last plug.
Old 08-19-2010, 11:50 AM
coil wires ohms good, had new cap and rotor but will try old one just because it ran with those. had friend with new cap that was a little off in size and took 2 days to figure it out. didn't check to see if rotor is turning though. good idea. will let you know
Old 08-19-2010, 11:54 AM
took off head after engine was upside down. new head gasket. nice and clean inside. Installed new plugs already. didn't use new plug wires but have 2 used sets that ran just fine before starting project. plan on testing crank sensor or just swapping it out today. Maybe damaged it during the swap?
Old 08-19-2010, 12:00 PM
This is a simple electrical trace. You have spark at the coil, so make sure the spark is getting to the distributor, and that the rotor is turning when the starter cranks. After that it's just connectivity to the plugs, through the cap and wires. Having the wrong size cap on there for 2 days is probably a big part of the issue.
Old 08-19-2010, 12:20 PM
my friend had the wrong cap on her car after a rebuild. she just mentioned it as a possible problem for me. I think my new cap and rotor are fine but I will put on the old ones just to make sure.
I still need to make sure the rotor is turning, but don't the sensors and ecu control the spark timing inside the distributor? or do they control spark timing at the coil? If I have spark at the coil does that mean that my crank position sensor is working fine?
Old 08-19-2010, 12:27 PM
just checked my rotor. it's rotating just fine, but wife heading off to work so I have to watch kid. will swap old cap tonight
Old 08-19-2010, 12:29 PM
Cool, so rotor's turning.
I'd install the cap and rotor, and the new plugs. Start with 1 plug out so you can test spark there. If no spark, then it's time to trace back to the distributor cap and see if there's spark where the plug wires hook up.
Old 08-20-2010, 10:43 PM
Just letting those following this that I'll start a new thread as problems have changed. No no spark anywhere. So today I bought and replaced crank position sensor, plug wires, and coil. Still no spark so put back the original distributor. Nothing. Tomorrow will try to borrow analogue volt meter to test cam position sensor and swap out computers (ecu, pmc, whatever it's called). running out of options here. shotgun maybe.
