Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 08-18-2010, 12:29 PM
userpete1037 userpete1037 is offline
Cool 97 Cadillac Deville (Rear Suspension)
Hello,
I jacked my cadillac up in the rear and replaced the rotors and pads. When I let it down, the rear is sitting higher than it was before I jacked it up. Does anyone know why this is?
Old 08-18-2010, 07:10 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 Cadillac Deville (Rear Suspension)
Unless you broke or disconnected the level ride sensor link the car should return to level after the key is left on for a few minutes.
Old 08-20-2010, 07:55 PM
What is the level ride sensor link and where is it?
Old 08-21-2010, 11:36 AM
A990 racer
If equipped there should be a link from the rear control arm to a sensor.
Old 02-06-2015, 12:59 AM
jinxyzboi jinxyzboi is offline
look under the passenger side behind the right rear wheel. You will see a small rod connected to the air level monitor, a small black box connected to frame and the other end of the rod to rear trailiing arm. The rod will have a push on black ball at the end. Make sure that is connected, they pop off easily.
Old 02-08-2015, 05:35 PM
I should've posted what was the issue. When I changed he rotors and pads, it was over a few days and I had disconnected the hose to the shocks so air had got in them. After that I discovered the shocks were bad along with the shock pump. Needless to say all that has been fixed and working fine.
