Old 08-16-2010, 03:21 PM
Black_Blade Black_Blade is offline
Getting drive belt off 2002 Winstar
I need to replace my alternator and thankfully it is readily accesible, but the belt tensioner is not. It looks like the only way to get a wrench on it is from underneath, which means getting it up either on jack stands or some other means of elevation. Just wondering what others have done to get at that tensioner pulley
Old 08-16-2010, 04:08 PM
mark_gober mark_gober is offline
Re: Getting drive belt off 2002 Winstar
Right answer....they sell a belt tensioner tool that is basically a 3/8" rathet (minus the ratcheting assy) attached to a long thin piece of steel. You can quickly and easily loosen the tensioner with it. It's probably around $15. (Worth it....trust me)
Quick answer, you can pull the belt with your hand and get enough slack to remove it from any of the easily accessible pullies. That gets it off, but you'll have hell getting it back on with the right tool.
I don't spend money unless I have to, but this is a tool that you'll be glad you bought.
Mark
Old 08-16-2010, 05:02 PM
Mark
Just checked Canadian Tire and sure enough they have this tool, but it's $40...just wondering if it can be rented, or its not something I will use all that often and $40 is a bit much for a one time use...although what is the price of avoided aggravation...
Old 08-16-2010, 06:35 PM
12Ounce 12Ounce is offline
Its not too difficult too reach under with a 13 mm closed end wrench and too take the tension off the tensioner... I just did it two days ago when I replaced my alternator. But I did remove the front right wheel ... not absollutely necessary ... just made things easier.
Old 08-16-2010, 08:53 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Originally Posted by 12Ounce View Post
Its not too difficult to reach under with a 13 mm closed end wrench and taking the tension of the tensioner... I just did it two days ago when I replaced my alternator. But I did remove the front right wheel ... not absollutely necessary ... just made things easier.
I did the same thing except for removing the wheel, I only crawled under the van from the front right corner and I could easily reach the belt tensioner without any issues, I used the same 13mm wrench.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-16-2010, 10:32 PM
Waxhaw Waxhaw is offline
Same here with a 13 mm wrench last weekend. I turned the wheels hard right to open space in front of right wheel, felt through and under the wheel well with the box end to get it on the tensioner. Turned the wrench to slacken tensioner with one hand while reaching over the fender with the other to flick the belt off, released tensioner.
When installing put the belt on everything except the top area and slacken the tensioner the same way to finish installing the top of belt. It would be a bit easier with two people!
Make sure it's in park with the emergency brake on..
cheers,
Waxhaw
'85 VW Jetta diesel 150k '95 Taurus 3.8 137k
2001 Windstar 3.8 126k
Old 08-17-2010, 07:03 PM
Seizer's Avatar
Seizer Seizer is offline
Here's the pic from the the incredibly crappy Ford service manual. Have to do this this weekend as well, hope the spring clip is there will make it easier.
Instructions are this.
1. Remove the drive belt.
1 Rotate the belt tensioner counterclockwise.
2 Push the spring clip towards the belt tensioner to lock belt tensioner in place.
2. To install, reverse the removal procedure.
Old 08-17-2010, 07:13 PM
joeuser742 joeuser742 is offline
cheers,
I agree with this one, I just got done working on my 2003 and must have taken the belt off and on about 6 times this way. It's the cheapest, quickest, and easiest way.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 08-17-2010, 07:20 PM
olopezm's Avatar
Wow! I had no idea about that clip, it should make things a lot easier I needed help from somebody else to install the belt, if I should have known about it I shouldn't had been bothering my mom! XD LOL.
Oscar
Old 08-17-2010, 07:42 PM
Grabber5.0 Grabber5.0 is offline
+1 for the wrench.
Old 08-19-2010, 04:04 PM
Got it off with the box end wrench, but enlisted the help of my son, for I had wormed my way in under the front corner with the wheels turned sharply to the right for more room. I should have checked this post again beforehand though...to look for that spring clip...although didn't see anything while was under the vehicle.
Alternator at CTC, $305 taxes in.... Ah well, what can ya do...start riding a bicycle?
Still have to do the back brakes, and right lower control arm but those are stories on their own...lol.
thanks for the suggestions guys!
Old 04-11-2012, 09:10 PM
Windstartled Windstartled is offline
That infamous clip appears to be quite elusive and only accessible to the lucky few. Did not exist at all on the tensioner I replaced today. On the new tensioner the pulley was held back by a single-use metal pin. In theory this would allow one to install the tensioner by themselves and remove the pin when done to pick up the slack in the belt. In practice however, it is impossible to install the tensioner with this pin in place because it blocks access to Bolt #2. Bolt #1 (bottom) was very easy to remove and re-install, Bolt #2 somewhat frustrating and Bolt #3 (top) took me an hour just to get it out and I could never reinstall it afterwards and it will stay that way until I can find an ultra-slim, 3-foot-long 10mm wrench. Have no idea if such a contraption even exists
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Old 04-12-2012, 05:55 AM
The alternator story continued for me this January, the previously mentioned alternator from Canadian Tire, last just under two years and had to be replaced. I did it all by myself this time, and my 'clip' to hold the tensioner off the belt...a small pc of wood wedged between my power bar and the under carriage
Sure wish could have found the reciept for that POS alternator from crappy tire
At the moment, the van is parked and am riding my bicycle to work...the repairs on this vehicle pile up up faster than the money to do them!!
  1. The flexible exhaust connector pipe between cat and muffler
  2. The ignition coil pack (again just over 2 yrs since last one)
  3. Noticed the rad is steaming while at stop light, so some pinhole leak there
  4. Body work..but don't think will ever get to that, for have no way or place to tackle it
Old 04-12-2012, 08:46 AM
Clever, I should've thought of that. In order to re-install the belt I ended up using a small hydraulic jack to push and hold the pulley forward. In order to avoid crushing the belt against the pulley I used a steel door hinge to press against the pulley's axle. Cussed and swore all evening long with this job but it was well worth the effort, got rid of the grinding noise that's been driving me nuts for over a year.
I only go to CT for tools and basic generic parts such as exhaust pipes, battery cables and such. For moving parts I used to shop online or at NAPA until I noticed that local generic auto parts retailers sell the exact same brands for less. Regarding the alternator last time mine fried I replaced it with one purchased at a junkyard for $10, figuring it would hold me 'til I could purchase a new one. That was 3 years ago and it still works flawlessly lol.
Regarding the flex pipe the one I got at CT works great, to my amazement (and theirs as well I'm sure ). The ones I had found online were overpriced.
Old 04-12-2012, 09:01 AM
I was looking at the flex pipe fittings in CT, but since the bolts connecting the flex to the cat is all corroded and really need to be cut off, just not sure what kind of bolts they are. If I cut them off with a grinder or sawsall, are they threaded into the flange on the cat? or is it just a bolt with nut on one side? Mine are too corroded to be able to tell...
