starting problems
I have a 95 chevy caprice with 5.7. Just recent I have come on this problem. when I try to start up it will not, but after a few turns it will. when it starts up it sounds as if it's not getting any gas when it first starts up. Then you can hear the motor turn up as the gas flows. This happens some times. I drive the car after that and it's fine. Could some one please help with this problem?
Re: starting problems
When was the last time you had the fuel filter changed?
If it has been a while, I would try that first and see what happens.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
about a year but only drove my car maybe 5 times since that could it still be the problem?
if you don't use this vehicle much always use a fuel stabilizer.. could also be corroded connections at the ECT sensor or the sensor itself. measure the fuel pressure to be sure the fuel pump/filter is ok .pressure should be about 47psi . need a fuel pressure guage. this is with the lack of any dtc failure codes/service engine light. |
