Go Back   Automotive Forums Car Chat > Ford > Excursion
Old 08-15-2010, 06:23 PM
mikeolivertx mikeolivertx is offline
05 excursion powerstroke wont start hot
05 powerstroke wont start hot , If i drive it 5 minutes and turn it off it will crank, hard and fast but wont fire.... wait 2 hrs and no problem... wait an hour and put the pedal to the floor it sputters and will start, fuel pump ??? It runs normal and great when it is running... just if i stop and turn it off.
>>> empty the fuel water seperater.
>>> lucas injector cleaner thru it twice
>>> added more fuel 7/8 full ????
not sure where to start with this one ... thinking electric fuel pump.
Old 08-15-2010, 09:11 PM
Franco2112 Franco2112 is offline
Re: 05 excursion powerstroke wont start hot
Bad egr valve. Clogged with carbon. Cold a egr valve partially clogged will allow cold eg's pass(because there are not as many hot gases), but once it's hot it will stick open and you will get a lean fuel mixture and no start issues, along with poor performance. F250's with power stroke engine from 1999-2005 had all kinds of egr valve issues. Clean your egr valve and you should notice a difference.
Franco
Old 08-21-2010, 09:52 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
That is completly wrong, EGR wont cause a no start when hot, it needs the STC bracket on the back of the high pressure oil pump, the quick connect is leaking. promise.
PS franco, 99-03.5 had no egr valve, 6.0 only, witch is 03.5-07. Good day sir.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
