Old 08-15-2010, 04:24 PM
fromhere2there fromhere2there is offline
Turn signal smokes
91 Lumina, 3.1
When I use the turn signal I have to pull it back towards me just slightly for it to work, a little smoke comes up from the steering colum. Am I going to ruin something if I keep using my turn signal? Or do I need to replace the signal switch.
Old 09-26-2010, 05:23 PM
JohnMarsh JohnMarsh is offline
Re: Turn signal smokes
just wondering if you found the problem. I have the same problem but there is no smoke.
Old 09-26-2010, 06:07 PM
Blue Bowtie's Avatar
Registered Offender
The multifunction switch on the column is a common failure item.
Old 09-27-2010, 09:53 AM
No it hasn't done it again and everything seems to still work.
Old 09-27-2010, 04:37 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Replace the turn signal switch. As previously mentioned it fails quite often.
Unfortunately, the issue often goes unnoticed to the driver because everything appears to be working fine. However, what happens when the switch fails is that only the middle/3rd brake light comes on when applying the brakes and neither of the rear turn signals actually turn on despite the front turn signals working fine and blinking at a normal pace along with the turn signal indicator lights in the dash.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
