Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-15-2010, 04:24 PM
fotwenty fotwenty is offline
Dual exhaust on 86 landau
Hi. I've been wanting to put true duals on my 86 caprice for a while now. I know of the crossmember issue but was wondering what I can do about it. I've seen numerous caprices in my year range with true duals so I know it's possible. Can u swap in a different crossmember? Or beat the crap outta the driver side of mine to clear the exhaust? Is there anyone on this site that already has duals and would like to show me a pic? Any help would be appreciated.
Old 08-15-2010, 06:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Dual exhaust on 86 landau
Weld a 1" inward extension to the left side of the frame, where the crossmember bolts, and use a "Tri-9" LT1 crossmember.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-15-2010, 08:12 PM
Thanks for the info but unfortunately i dont currently have access to a welder. Anything else i could do?
Old 08-16-2010, 07:59 PM
j cAT j cAT is offline
go to a custom muffler shop . they will cut/weld the support , for this to be proper. go to a place that has done this. I have a shop my way that makes this look better than OEM.
you need a welder and metal cuting equiptment
Old 08-16-2010, 10:59 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
If you are getting a custom-bent exhaust system made, there is a slightly easier way.
Route the left side exhaust under the oil pan or converter housing. Then run both exhaust pipes through the stock cross member hump, on the right side of the transmission.
Then route the left side pipe under thr driveshaft just behind the trans tail stock. Then run both pipes over the rear axle, to the rear bumper, with mufflers just in front of the rear axle.
I did this on my '81 Fleetwood (with headers),which has the same frame as your Caprice (but a bit longer). This set up has plenty of clearance, is neat and trouble-free.
