new head gasket installed wont start?
I just finished installing a new head gasket with all other required gaskets and now the metro will not turn over. quite disapointing. I am thinking it is something to do with the timing/belt. the vehicle smells like it is getting fuel into the cylinders but no combustion. I lined the crankshaft notch and the camshaft notch to both be pointing nearly stright up. this put the distributor back into top center position for the pistons. For the crankshaft i am using the little potrusion that the pully fits onto as the mark, is this correct? are there any other ideas out there?
i have triple checked all the hose and wiring connections, all seem to be put back correctly. i did not remove the distributor during the head removal so that should still be good. |
Re: new head gasket installed wont start?
http://geometroforum.com/topic/2232748
for good pictures of the timing marks Also, check the bundle of ground wires that connect just below the throttle body, lots of folks forget to re-attach those and they're the grounds for pretty much everything.
Woodie 98 Metro and 06 Aerio SX Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change http://www.garyjohnson2012.com |
I had trouble getting my 95 to get going after replacing the head gasket. In my case, the trouble was the head itself. It had become too fouled from running with one cylinder always wet with oil from ring blow-by... probably not your problem. Like you suspect and Woodie says, check the timing. The 96 timing gear has two marks on opposite ends. You may try the other one. The other thing it could be is that you are on TDC on the exhaust stroke? I'm not sure if I explained that right, but on one timing belt change my first attempt failed, but when I advanced the engine to the next TDC on cyl 1, it worked.
Good luck, Jai
96 3 cylinder Geo Metro (currently being rebuilt) |
Thanks for the help guys. turns out my timing was 180 degrees off. my camshaft wheel has two marks on it, i do not know if that is standard are not but it sure makes things confusing. I adjusted it 180 degrees and wam bam started right up with no problems surfacing yet.
