Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 08-14-2010, 01:10 PM
sprintwrench5556 sprintwrench5556 is offline
'01 Tracker cylinder misfire
'01 Tracker 2.0 check engine light is on. Code reader was #3 cylinder misfire. I replaced the coil pack on #3 cylinder and all plugs, cleared the code. The engine still runs like is has a misfire. Check engine light came back on reader now reads multiple cylinder misfire detected but. Any ideas? I also done a compression check all cylinders are as follows #1 185 #2 195 #3 195 #4 195. Changed the fuel filter and removed the fuel injectors cleaned them w/ aerosol spray cleaner. Still no change. I adjusted the cam-shaft position sensor, the engine misfire has let up some but not completely. I've cleared the code but don't know if it will come back. HELP!
Old 09-17-2010, 03:44 PM
pegleg55 pegleg55 is offline
Re: '01 Tracker cylinder misfire
have you changed the plugs and made shure they are gapped correctly?
Old 09-27-2010, 07:34 PM
rhandwor rhandwor is offline
Use a noid light and make sure you have power to this injector. Use a stethoscope and listen to the injector make sure its working properly.
Ohm the injector and compare to the other injectors.
Pull the plug wire put in a spark plug ground the plug have someone else crank the motor. Make sure its sparking maybe a bad wire between the coil pack and spark plug.
Old 09-27-2010, 08:51 PM
danielsatur danielsatur is offline
If the misfire is still on cylinder 3, roll the injector to another pos.
Old 10-10-2010, 08:09 PM
Misfire is now a rolling misfire between all the cylinders it is no longer just #3. The code reader now reads cylinder misfire detected it is no longer cylinder specific. I have now retarded the cam position sensor all the way the misfire is no longer read by the computer but the engine is down on power.
Old 10-10-2010, 08:12 PM
quote "I changed the #3 coil pack and ALL plugs".
