Old 08-14-2010, 08:43 AM
albur albur is offline
2001 dodge caravan-electrical problem
I have a 2001 caravan.It runs fine but all dash guages quit along with the turn signals & 4 ways.Everything else is working fine.Any suggestions would be appreciated.
Old 08-14-2010, 01:46 PM
Alphabravo Alphabravo is offline
Re: 2001 dodge caravan-electrical problem
I'm not sure if this problem persits with 01 and newer models, but it has been a frequent problem with the older vans. It could be a bad slder joint on the instrument cluster circuit board. It's not a hard fix in you know how to solder.
just search this forum for "instrument cluster solder" and you'll find many threads on it.
Good luck.
Old 08-14-2010, 01:52 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Check the hazards flasher fuse. It kills power to the part of the BCM that controls flashers, turn sigs and for some reason, the instrument cluster.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
