Old 08-13-2010, 04:35 PM
Kybar Kybar is offline
Angry 97 mustang misfire.. going crazy
I have a 97 mustang Gt 4.6 V8. I have been popping a code for cylinder 5 misfire. replaced plugs wires coil packs swapped injectors and have checked vaccuum lines. yet still doggish and showing a misfire. compression good in cylinder and not burning oil. Im confused.. any other idea's
Old 08-13-2010, 10:27 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 97 mustang misfire.. going crazy
After you swapped the wire and injector it still misfires on cylinder 5? Is the 97 still EDIS or COP ignition? If COP, maybe their is a problem with the electrical connector? Infact, I suppose it could be the connector on the fuel injector, too.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
