Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-13-2010, 03:48 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
FYI: worked on an idea, and it worked out (for me)
I have been wrestling with my transmission tunnel as well as the ability to fill it when changing fluid - so, I finally decided to cut my tunnel in 3 pieces - top and 2 sides, welded some flat stock on the back, nut inserts and now I have a very removeable tunnel when the need arises -- no more taking out the seat(s) to do any type of work.
Just FYI....
Devin
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 08-13-2010, 05:42 PM
PanozDuke PanozDuke is offline
Re: FYI: worked on an idea, and it worked out (for me)
Devin,
I think that is a great idea. I think I'll do it in aluminum while I'm at it.
Mike
Old 08-13-2010, 07:20 PM
Gatorac's Avatar
Gatorac Gatorac is offline
I made a new 3 piece tunnel out of 24ga sheet metal. I think it must be 500lbs lighter then the original tunnel.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 08-14-2010, 07:46 AM
Jim woodruff's Avatar
Jim woodruff Jim woodruff is offline
Now thats a great Idea. The gasket material for the front of the tunnel ,we used fiberglass packing rope from a fireplace shop. Glued it in place and works great.
Jim Woodruff
Akron, Ohio
Old 08-14-2010, 09:41 AM
Cobrafang Cobrafang is offline
Just FYI....
Devin
To quote Eric, this thread is fiction with out photos!
Well I used different words.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 08-14-2010, 11:27 AM
Gatorac's Avatar
I made one for Jimimac and I don't think he's put it in the car yet. Maybe he can post up a couple of pics.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 08-15-2010, 08:17 AM
David Eastman David Eastman is offline
Now I know how a red headed step child feels.
Old 08-15-2010, 02:31 PM
Gatorac's Avatar
How about, I gave my first draft to Jimimac and made me a better one. Crybaby
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 08-15-2010, 07:45 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
I like the idea of making refilling the tranny easier.
During my quest to remove weight from the Panoz I remade the tunnel from sheet alum. I didn't go to the extent of making it multi-peice (which sounds like a great idea!), since I also removed the passenger seat to save 32 lbs (with harness removed too). I used weather strip to make the seal to the interior, and insulated the inside with some of that hi-tech multi-layer aluminum. Holding up pretty well so far.
Jerry
1999 Panoz GT-RA
Old 08-16-2010, 07:10 PM
Panoz26's Avatar
Sorry. Been busy getting the car ready for VIR. I can send pics of it installed.
Devin
Old 08-16-2010, 08:25 PM
Gatorac's Avatar
No need for heat shielding in the roadster. Nice and cool inside.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 08-16-2010, 10:33 PM
Hook a Brother up.
Old 08-17-2010, 10:16 AM
Hook a Brother up.
Hey David,
Since I can't get the guys with the setup to post pictures I thought I would ask the guy who does not have it in the hopes you have the pictures?
Racer and Gamer
Old 08-17-2010, 08:13 PM
panozracing's Avatar
panozracing panozracing is offline
OK...OK....Enough with the begging.....
I have an aluminum one piece tunnel that I very simply added an access panel right where the fill hole is and you can remove the panel with a screw driver. A little heat mat on the drivers side and your set. K.I.S.S. words to live by!!!
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
